주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony FDL-220R Watchman Button Replacement
필요한 것
    1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 1 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 1 단계, 이미지 2개 중 2개
      • Press down on the textured area and push towards the bottom of the device.
      • Gently remove the battery cover.
      • Remove the three AA batteries.
      댓글 쓰기
    2. Sony FDL-220R Watchman Button Replacement, Remove screws: 2 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove screws: 2 단계, 이미지 2개 중 2개
      • Locate the five 5x11mm screws surrounding the battery compartment.
      • Remove screws with a Philips #00 screwdriver.
      댓글 쓰기
    3. Sony FDL-220R Watchman Button Replacement, Remove back casing: 3 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove back casing: 3 단계, 이미지 2개 중 2개
      • Grasp the entire back half of the Watchman's casing.
      • Snap off the casing from the bottom of the device.
      • Gently pull off entire back casing.
      댓글 쓰기
    4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: 4 단계, 이미지 3개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 4 단계, 이미지 3개 중 2개 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 4 단계, 이미지 3개 중 3개
      • Carefully grasp the entire circuit board.
      • Pull the circuit board off of the device's plastic casing.
      댓글 쓰기
    5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 5 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 5 단계, 이미지 2개 중 2개
      • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
      • Buttons/switches should be simply resting in their slots on the device.
      • Remove all three buttons/switches.
      • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
      • If one of the buttons/switches is broken, simply replace it with a new one.
      • When replacing, make sure that the slot on the switches faces up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sam Putnam
회원 가입일: 10/22/14
484 평판
안내서 4개를 작성함
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 6
지난 30일: 27
전체 시간: 568
