주요 콘텐츠로 건너뛰기
Sony FDL-220R Watchman Battery and Battery Contacts Replacement
필요한 것
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: 1 단계, 이미지 1/2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: 1 단계, 이미지 2/2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: 2 단계, 이미지 1/1
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: 3 단계, 이미지 1/2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: 3 단계, 이미지 2/2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: 4 단계, 이미지 1/2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: 4 단계, 이미지 2/2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: 5 단계, 이미지 1/1
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
결론
Sam Putnam
회원 가입일: 10/22/14
484 평판
안내서 4개 작성하였습니다
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 11
전체 시간: 494
