주요 콘텐츠로 건너뛰기
Sony FDL-220R Watchman Speaker Replacement
필요한 것
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: 1 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: 1 단계, 이미지 2개 중 2개
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: 2 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Speaker Replacement, Remove screws: 2 단계, 이미지 2개 중 2개
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: 3 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Speaker Replacement, Remove back casing: 3 단계, 이미지 2개 중 2개
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: 4 단계, 이미지 3개 중 1개 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: 4 단계, 이미지 3개 중 2개 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: 4 단계, 이미지 3개 중 3개
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: 5 단계, 이미지 3개 중 1개 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: 5 단계, 이미지 3개 중 2개 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Putnam
회원 가입일: 10/22/14
484 평판
안내서 4개를 작성함
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G5
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 415
