주요 콘텐츠로 건너뛰기
Sony H.ear On 2 Bluetooth Transceiver Replacement
필요한 것
  1. Sony H.ear On 2 Bluetooth Transceiver Replacement, Ear Cup: 1 단계, 이미지 1/2 Sony H.ear On 2 Bluetooth Transceiver Replacement, Ear Cup: 1 단계, 이미지 2/2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Bluetooth Transceiver Replacement: 2 단계, 이미지 1/2 Sony H.ear On 2 Bluetooth Transceiver Replacement: 2 단계, 이미지 2/2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Bluetooth Transceiver Replacement, Bluetooth Transceiver: 3 단계, 이미지 1/2 Sony H.ear On 2 Bluetooth Transceiver Replacement, Bluetooth Transceiver: 3 단계, 이미지 2/2
    • Then, turn the ear cup over and carefully lift the plastic cover off to reveal the internal components of the right ear cup.
    • Unlike the right ear cup, there is no ribbon cable directly connecting the rest of the headphones to the outer cup.
  4. Sony H.ear On 2 Bluetooth Transceiver Replacement: 4 단계, 이미지 1/3 Sony H.ear On 2 Bluetooth Transceiver Replacement: 4 단계, 이미지 2/3 Sony H.ear On 2 Bluetooth Transceiver Replacement: 4 단계, 이미지 3/3
    • Using the JIS #00 screwdriver, remove the two 6.4 mm screws holding the NFC chip in place over the motherboard.
    • Once the screws are removed, gently turn over the board to the left to expose the soldered connection points.
  5. Sony H.ear On 2 Bluetooth Transceiver Replacement: 5 단계, 이미지 1/2 Sony H.ear On 2 Bluetooth Transceiver Replacement: 5 단계, 이미지 2/2
    • Using a soldering iron, carefully de-solder the two connection points on the NFC chip.
    • Once the solder has completely melted, carefully separate the wires and the NFC chip itself.
    • Please see How to Solder and Desolder Connections before you attempt to use the soldering iron.
결론
Peter Van Ness
회원 가입일: 04/15/19
147 평판
안내서 1개 작성함
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 회원
CPSU-MANESS-S19S9G11
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 21
전체 시간: 1,336
