주요 콘텐츠로 건너뛰기
Sony H.ear On 2 Microphone Replacement
필요한 것
  1. Sony H.ear On 2 Microphone Replacement, Ear Cup: 1 단계, 이미지 1/2 Sony H.ear On 2 Microphone Replacement, Ear Cup: 1 단계, 이미지 2/2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Microphone Replacement: 2 단계, 이미지 1/2 Sony H.ear On 2 Microphone Replacement: 2 단계, 이미지 2/2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: 3 단계, 이미지 1/3 Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: 3 단계, 이미지 2/3 Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: 3 단계, 이미지 3/3
    • Use the iFixit plastic opening tool to lift the microphone out of its housing
    • Use gentle pressure to prevent damaging small wire connections
  4. Sony H.ear On 2 Microphone Replacement: 4 단계, 이미지 1/2 Sony H.ear On 2 Microphone Replacement: 4 단계, 이미지 2/2
    • Use soldering iron to desolder microphone wires from motherboard
    • Please see How to Solder and Desolder Connections before you attempt to use the soldering iron.
    • Note: Do not overheat joints while de-soldering to prevent board damage
결론
다른 3명이 해당 안내서를 완성하였습니다.
Justin Ramirez
회원 가입일: 04/15/19
127 평판
안내서 1개 작성함
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 회원
CPSU-MANESS-S19S9G11
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 26
전체 시간: 2,083
