주요 콘텐츠로 건너뛰기
Sony Handycam DCR-SR42 LCD Screen Replacement
필요한 것
  1. Sony Handycam DCR-SR42 LCD Screen Replacement, Hard Drive: 1 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 LCD Screen Replacement: 4 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 LCD Screen Replacement: 5 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 LCD Screen Replacement, Internal Components: 8 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement, Internal Components: 8 단계, 이미지 2/2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 LCD Screen Replacement: 9 단계, 이미지 1/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 9 단계, 이미지 2/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 9 단계, 이미지 3/3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 LCD Screen Replacement: 10 단계, 이미지 1/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 10 단계, 이미지 2/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 10 단계, 이미지 3/3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
  11. Sony Handycam DCR-SR42 LCD Screen Replacement: 11 단계, 이미지 1/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 11 단계, 이미지 2/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 11 단계, 이미지 3/3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 LCD Screen Replacement: 12 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 12 단계, 이미지 2/2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 LCD Screen Replacement: 13 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 13 단계, 이미지 2/2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 LCD Screen Replacement, Flex Cable: 14 단계, 이미지 1/1
    • Remove the 5 3mm Phillips #00 Screws from the screen assembly.
  15. Sony Handycam DCR-SR42 LCD Screen Replacement: 15 단계, 이미지 1/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 15 단계, 이미지 2/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 15 단계, 이미지 3/3
    • Carefully lift up the sound chip and peel the flex cable off the screen case.
    • Lift off the plastic bracket from the hinge.
  16. Sony Handycam DCR-SR42 LCD Screen Replacement: 16 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 16 단계, 이미지 2/2
    • Remove the screen from the plastic case by pulling the flex cable and sound chip through the hole in the case.
  17. Sony Handycam DCR-SR42 LCD Screen Replacement: 17 단계, 이미지 1/1
    • Turn the hinge sideways and remove the two 4mm Phillips #00 screws from the side of the screen.
  18. Sony Handycam DCR-SR42 LCD Screen Replacement: 18 단계, 이미지 1/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 18 단계, 이미지 2/3 Sony Handycam DCR-SR42 LCD Screen Replacement: 18 단계, 이미지 3/3
    • Use the plastic opening tool to remove the plastic hinge covers and expose the metal hinge.
    • Unwrap the flex cable from around the hinge.
  19. Sony Handycam DCR-SR42 LCD Screen Replacement: 19 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 19 단계, 이미지 2/2
    • Use the plastic opening tool to open the screen case.
  20. Sony Handycam DCR-SR42 LCD Screen Replacement: 20 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 20 단계, 이미지 2/2
    • Unplug the flex cable from the sound chip.
    • Unplug the flex cable from the screen chip.
  21. Sony Handycam DCR-SR42 LCD Screen Replacement, LCD Screen: 21 단계, 이미지 1/1
    • Unscrew the 2mm Phillips #00 screw from the screen chip.
  22. Sony Handycam DCR-SR42 LCD Screen Replacement: 22 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 22 단계, 이미지 2/2
    • Remove the LCD screen and chip from the plastic case.
    • Separate the screen from the chip.
  23. Sony Handycam DCR-SR42 LCD Screen Replacement: 23 단계, 이미지 1/2 Sony Handycam DCR-SR42 LCD Screen Replacement: 23 단계, 이미지 2/2
    • Unplug the screen cable from the screen chip.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Dan Muller
회원 가입일: 03/23/15
1,020 평판
안내서 5개 작성하였습니다
Baylor, Team 7-13, Williams Spring 2015 Baylor, Team 7-13, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G13
4 회원들
안내서 10개 작성하였습니다
댓글 3개
Good narration,but very sofia fixated parts and needs to handle gently and carefully.not an easy
dvsureshkreddy - 답글
What’s a link to a replacement screen?
Rick Astely - 답글
Had a loose hinge on the identical DCR-SR52 (screen was flopping around at the smallest movement), I could not have fixed it without this guide, thanks a lot.
IPaul 6253 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 45
전체 시간: 5,530
