주요 콘텐츠로 건너뛰기
Sony Handycam DCR-SR42 Lens Replacement
필요한 것
  1. Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: 1 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Lens Replacement: 2 단계, 이미지 1/1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Lens Replacement: 3 단계, 이미지 1/1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Lens Replacement: 4 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement: 4 단계, 이미지 2/2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Lens Replacement: 5 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement: 5 단계, 이미지 2/2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Lens Replacement: 6 단계, 이미지 1/1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Lens Replacement: 7 단계, 이미지 1/1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Lens Replacement, Internal Components: 8 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement, Internal Components: 8 단계, 이미지 2/2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Lens Replacement: 9 단계, 이미지 1/3 Sony Handycam DCR-SR42 Lens Replacement: 9 단계, 이미지 2/3 Sony Handycam DCR-SR42 Lens Replacement: 9 단계, 이미지 3/3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Lens Replacement: 10 단계, 이미지 1/3 Sony Handycam DCR-SR42 Lens Replacement: 10 단계, 이미지 2/3 Sony Handycam DCR-SR42 Lens Replacement: 10 단계, 이미지 3/3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 Lens Replacement: 11 단계, 이미지 1/3 Sony Handycam DCR-SR42 Lens Replacement: 11 단계, 이미지 2/3 Sony Handycam DCR-SR42 Lens Replacement: 11 단계, 이미지 3/3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Lens Replacement: 12 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement: 12 단계, 이미지 2/2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Lens Replacement: 13 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement: 13 단계, 이미지 2/2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Lens Replacement, Lens: 14 단계, 이미지 1/1
    • Remove the 3mm Phillips #00 screw from the underside of the camera near the lens housing.
  15. Sony Handycam DCR-SR42 Lens Replacement: 15 단계, 이미지 1/2 Sony Handycam DCR-SR42 Lens Replacement: 15 단계, 이미지 2/2
    • Use the plastic opening tool to pry the side casing off the camera.
  16. Sony Handycam DCR-SR42 Lens Replacement: 16 단계, 이미지 1/1
    • Remove the final 3mm #00 Phillips screw from the lens housing.
  17. Sony Handycam DCR-SR42 Lens Replacement: 17 단계, 이미지 1/1
    • Remove the lens housing from the camera.
  18. Sony Handycam DCR-SR42 Lens Replacement: 18 단계, 이미지 1/1
    • Remove the three 2mm Phillips #00 screws from around the lens.
  19. Sony Handycam DCR-SR42 Lens Replacement: 19 단계, 이미지 1/1
    • Remove the lens from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dan Muller
회원 가입일: 03/23/15
1,020 평판
안내서 5개 작성하였습니다
Baylor, Team 7-13, Williams Spring 2015 Baylor, Team 7-13, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G13
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 786
