주요 콘텐츠로 건너뛰기
Sony Handycam FDR-AX33 Microphone Replacement
필요한 것
  1. Sony Handycam FDR-AX33 Microphone Replacement, Panel: 1 단계, 이미지 1/2 Sony Handycam FDR-AX33 Microphone Replacement, Panel: 1 단계, 이미지 2/2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 Microphone Replacement: 2 단계, 이미지 1/3 Sony Handycam FDR-AX33 Microphone Replacement: 2 단계, 이미지 2/3 Sony Handycam FDR-AX33 Microphone Replacement: 2 단계, 이미지 3/3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 Microphone Replacement: 3 단계, 이미지 1/2 Sony Handycam FDR-AX33 Microphone Replacement: 3 단계, 이미지 2/2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 Microphone Replacement: 4 단계, 이미지 1/2 Sony Handycam FDR-AX33 Microphone Replacement: 4 단계, 이미지 2/2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 Microphone Replacement: 5 단계, 이미지 1/3 Sony Handycam FDR-AX33 Microphone Replacement: 5 단계, 이미지 2/3 Sony Handycam FDR-AX33 Microphone Replacement: 5 단계, 이미지 3/3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 Microphone Replacement: 6 단계, 이미지 1/3 Sony Handycam FDR-AX33 Microphone Replacement: 6 단계, 이미지 2/3 Sony Handycam FDR-AX33 Microphone Replacement: 6 단계, 이미지 3/3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 Microphone Replacement: 7 단계, 이미지 1/2 Sony Handycam FDR-AX33 Microphone Replacement: 7 단계, 이미지 2/2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 Microphone Replacement: 8 단계, 이미지 1/3 Sony Handycam FDR-AX33 Microphone Replacement: 8 단계, 이미지 2/3 Sony Handycam FDR-AX33 Microphone Replacement: 8 단계, 이미지 3/3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 Microphone Replacement, Microphone: 9 단계, 이미지 1/1
    • Pry up the plastic frame around the camera’s microphone.
    • Be careful with the thin plastic frame as it might break. If it does break, it shouldn't affect the camera's performance.
  10. Sony Handycam FDR-AX33 Microphone Replacement: 10 단계, 이미지 1/1
    • Pull back clips to release microphone.
  11. Sony Handycam FDR-AX33 Microphone Replacement: 11 단계, 이미지 1/3 Sony Handycam FDR-AX33 Microphone Replacement: 11 단계, 이미지 2/3 Sony Handycam FDR-AX33 Microphone Replacement: 11 단계, 이미지 3/3
    • Desolder the three connections on the bottom of the microphone. Refer to the soldering guide linked here.
    • Remove the two 3 mm Phillips #00 screws to release the microphone mount.
    • Removing the microphone mount is not required to replace the microphone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Casey
회원 가입일: 01/24/19
187 평판
안내서 1개 작성함
Cal Poly, Team S18-G2, White Winter 2019 Cal Poly, Team S18-G2, White Winter 2019 회원
CPSU-WHITE-W19S18G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 595
