주요 콘텐츠로 건너뛰기
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: 1 단계, 이미지 1/3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: 1 단계, 이미지 2/3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: 1 단계, 이미지 3/3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: 2 단계, 이미지 1/1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: 3 단계, 이미지 1/2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: 3 단계, 이미지 2/2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: 4 단계, 이미지 1/1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
L Cis
회원 가입일: 10/10/14
110 평판
안내서 1개 작성함
USF Tampa, Team 1-8, Donnelly Fall 2014 USF Tampa, Team 1-8, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 38
전체 시간: 4,639
