주요 콘텐츠로 건너뛰기
Sony RM-LVR1 LCD Screen Replacement
필요한 것
  1. Sony RM-LVR1 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 2개 중 1개 Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 2개 중 2개
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
  7. Sony RM-LVR1 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Sony RM-LVR1 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the screen from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alexander Thomas
회원 가입일: 09/28/17
265 평판
안내서 2개를 작성함
4가이드 댓글
здорово!
подскажите где купить дисплей?, или его маркировку?. на дисплее ничего не написано, не могу найти.
Александр - 답글
Hi
I cant find an replacement lcd.
Could anybody help me where to get one?
Cheers
Sven
Sven van Bellen - 답글
any link to the replacement LCD please?
Bart Ptachowski - 답글
Hi .
search : HD 170 LCD Drift aliexp****
i think it will do the job .
cheers
ruigyl - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 726
