주요 콘텐츠로 건너뛰기
Sony RM-LVR1 Motherboard Replacement
필요한 것
  1. Sony RM-LVR1 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 Motherboard Replacement: 2 단계, 이미지 1/1
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 Motherboard Replacement, LCD Screen: 3 단계, 이미지 1/2 Sony RM-LVR1 Motherboard Replacement, LCD Screen: 3 단계, 이미지 2/2
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
  7. Sony RM-LVR1 Motherboard Replacement: 7 단계, 이미지 1/2 Sony RM-LVR1 Motherboard Replacement: 7 단계, 이미지 2/2
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the screen from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander Thomas
회원 가입일: 09/28/17
265 평판
안내서 2개 작성하였습니다
댓글 한 개
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 291
