소개
If the speaker inside your Sony SRS-XB13 device is damaged and no longer functioning as expected, this guide will inform you on how to remove the speaker for replacement. The speaker itself is the source of audio for the device and without it, the generation of sound is impossible.
Before using this guide, refer to the troubleshooting page. It provides information that could prove useful in resolving issues such as low volume or distorted sound, without the need of fully replacing the device's speaker.
Often times, a speaker that is played at an exceedingly high volume for extended periods of time can "go out" and no longer produce sound at the audio levels expected from it. When a speaker is incapable of producing any sound at all, it is usually time to replace it entirely.
필요한 것
To get the bottom part of the speaker off, take a long and sturdy screwdriver and put it through the holes at the bottom of the speaker.
When you have the screwdriver through the holes, you'll want to push down very firmly. Rotate between the holes and repeat this process until the bottom piece pops off.
Locate the four 11 mm screws along the base of the white center block.
Use the Phillips #1 screwdriver with the 150mm flex extension from the Mako Driver kit to unscrew and remove the screws from their positions.
이 단계에 사용된 도구:Tweezers$4.99
Use the blunt tweezers from the precision tweezers set to clamp down on a solid piece of the white center block.
With a firm grip, pull upwards with the blunt tweezers until the white center block is released from its position.
Locate the small brackets along the side of the white center block that hold the red, yellow, black, and white wires in place.
With your fingers, gently pull the wires away from the center block so that they are no longer held up by the brackets.
Flip the white center block over so that the black speaker is facing upwards.
Firmly grasp the speaker with your hands and pull it up and away from the center block until it fully disconnects from it.
