주요 콘텐츠로 건너뛰기
Sony SRS-XB43 Battery Replacement
필요한 것
  1. Sony SRS-XB43 Battery Replacement, Faceplate: 1 단계, 이미지 1/2 Sony SRS-XB43 Battery Replacement, Faceplate: 1 단계, 이미지 2/2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Battery Replacement: 2 단계, 이미지 1/1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Battery Replacement: 3 단계, 이미지 1/1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Battery Replacement: 4 단계, 이미지 1/2 Sony SRS-XB43 Battery Replacement: 4 단계, 이미지 2/2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Battery Replacement, Battery: 5 단계, 이미지 1/2 Sony SRS-XB43 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Battery Replacement: 6 단계, 이미지 1/3 Sony SRS-XB43 Battery Replacement: 6 단계, 이미지 2/3 Sony SRS-XB43 Battery Replacement: 6 단계, 이미지 3/3
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Battery Replacement: 7 단계, 이미지 1/2 Sony SRS-XB43 Battery Replacement: 7 단계, 이미지 2/2
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Battery Replacement: 8 단계, 이미지 1/2 Sony SRS-XB43 Battery Replacement: 8 단계, 이미지 2/2
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Luke Escobar
회원 가입일: 10/28/22
159 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
So, where can we buy a new battery to use these instructions for replacing it ?
Doubletap - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 33
30일 전: 166
전체 시간: 2,295
