주요 콘텐츠로 건너뛰기
Sony SRS-XB43 Port Housing PCB Replacement
필요한 것
  1. Sony SRS-XB43 Port Housing PCB Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Port Housing PCB Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Port Housing PCB Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Port Housing PCB Replacement: 4 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement: 4 단계, 이미지 2개 중 2개
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Port Housing PCB Replacement, Battery: 5 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Port Housing PCB Replacement: 6 단계, 이미지 3개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement: 6 단계, 이미지 3개 중 2개 Sony SRS-XB43 Port Housing PCB Replacement: 6 단계, 이미지 3개 중 3개
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Port Housing PCB Replacement: 7 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement: 7 단계, 이미지 2개 중 2개
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Port Housing PCB Replacement: 8 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement: 8 단계, 이미지 2개 중 2개
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
  9. Sony SRS-XB43 Port Housing PCB Replacement, Port Housing PCB: 9 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement, Port Housing PCB: 9 단계, 이미지 2개 중 2개
    • Orient the motherboard chassis so that the battery compartment is facing upwards.
    • Remove the button PCB by grabbing it by its sides and gently pulling it upwards.
  10. Sony SRS-XB43 Port Housing PCB Replacement: 10 단계, 이미지 2개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement: 10 단계, 이미지 2개 중 2개
    • Grab the port housing PCB and gently pull it upward to remove it from the chassis.
    • To the very left of the PCB, right next to the six metal pins facing upwards, is an empty space big enough to get a firm grip on the circuit board with your fingers which will help while removing it.
  11. Sony SRS-XB43 Port Housing PCB Replacement: 11 단계, 이미지 3개 중 1개 Sony SRS-XB43 Port Housing PCB Replacement: 11 단계, 이미지 3개 중 2개 Sony SRS-XB43 Port Housing PCB Replacement: 11 단계, 이미지 3개 중 3개
    • Locate the black ribbon cable with the blue tip plugged into the port housing PCB.
    • To unplug the ribbon cable from the PCB, grab it from its base and apply a suitable amount of force towards yourself until it becomes loose and disconnects.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bishoy Mikhail
회원 가입일: 10/26/22
352 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G5
4 회원들
안내서 5개를 작성함
8가이드 댓글
Tendría el enlace de compra del pcb?
Jaume3676 - 답글
Where do you get the port from?
Joseph Valencia - 답글
bonjour ou je peu acheter la piece avec usb c pour la remplacer merci
batbleu marc - 답글
Where can i buy the port from???
Carlos Mata - 답글
Where can I buy the port /part
LH.2037410
CN02580
SRS_XB43/BC. AU4
Robert Trinka - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 124
전체 시간: 3,295
