주요 콘텐츠로 건너뛰기
Sony SRS-XB43 Speaker Replacement
필요한 것
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: 1 단계, 이미지 1/2 Sony SRS-XB43 Speaker Replacement, Faceplate: 1 단계, 이미지 2/2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: 2 단계, 이미지 1/1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: 3 단계, 이미지 1/1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: 4 단계, 이미지 1/2 Sony SRS-XB43 Speaker Replacement: 4 단계, 이미지 2/2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: 5 단계, 이미지 1/3 Sony SRS-XB43 Speaker Replacement, Speaker: 5 단계, 이미지 2/3 Sony SRS-XB43 Speaker Replacement, Speaker: 5 단계, 이미지 3/3
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: 7 단계, 이미지 1/2 Sony SRS-XB43 Speaker Replacement: 7 단계, 이미지 2/2
    • Remove the two individual speakers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bishoy Mikhail
회원 가입일: 10/26/22
253 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 46
전체 시간: 967
