주요 콘텐츠로 건너뛰기
Sony Smart Watch SW2 Battery Replacement
필요한 것
  1. Sony Smart Watch SW2 Battery Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Set aside the detached LCD screen to access the battery.
  5. Sony Smart Watch SW2 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Lift one side of the battery up carefully. There is a thin black circuit adhered to the back of the battery that connects to the motherboard and the charger.
    • The connection is already broken in this image and you will not be able to lift the battery this high.
  6. Sony Smart Watch SW2 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Push the black piece down while very carefully pulling the battery off. Work your way around without lifting the black piece up too much.
  7. Sony Smart Watch SW2 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Once the battery is free from the frame adhesive, desolder the black and red battery wires.
    • Remove the battery.
결론
To reassemble your device, follow these instructions in reverse order after the battery is replaced.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Vincent Shiue
회원 가입일: 01/22/18
265 평판
안내서 2개를 작성함
IUPUI, Team S1-G5, Freund Spring 2018 IUPUI, Team S1-G5, Freund Spring 2018 회원
IUPUI-FREUND-S18S1G5
3 회원들
안내서 2개를 작성함
3가이드 댓글
HI
please from where can i get the battery i want new one you know any website sell this battery
thanks
hossamman2014 - 답글
I think AliExpress has some compatible batteries. I may order one too.
S. Pamnco -
Looked replacing battery but when I pushed the assembly free from the case I could see corrosion. Is it worth the trouble?
David Lewis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 30
전체 시간: 5,569
