주요 콘텐츠로 건너뛰기
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
필요한 것
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: 1 단계, 이미지 1/2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: 1 단계, 이미지 2/2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 2 단계, 이미지 1/2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 2 단계, 이미지 2/2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 3 단계, 이미지 1/1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: 4 단계, 이미지 1/2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: 4 단계, 이미지 2/2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 5 단계, 이미지 1/3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 5 단계, 이미지 2/3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: 6 단계, 이미지 1/2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: 6 단계, 이미지 2/2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Marii
회원 가입일: 01/08/15
658 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015 회원
CPSU-MANESS-W15S21G19
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 4,567
