이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
Remove the two rubber feet at the back of the computer, these can be removed in the same way.
Gently lift the small, black piece of tape located near the fan.
거의 끝나갑니다!
결론
댓글 한 개
Hey Alex!
Do you know if the fan is the same for the Sony Viao Pro 11 as the one for the Viao Pro 13?.
I can only see info for the fan for the 13.
Thanks!..
