주요 콘텐츠로 건너뛰기
Sony Vaio VGN-SZ120P Keyboard Replacement
필요한 것
  1. Sony Vaio VGN-SZ120P Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Keyboard Replacement: 2 단계, 이미지 1/1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Keyboard Replacement: 4 단계, 이미지 1/2 Sony Vaio VGN-SZ120P Keyboard Replacement: 4 단계, 이미지 2/2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Keyboard Replacement: 5 단계, 이미지 1/2 Sony Vaio VGN-SZ120P Keyboard Replacement: 5 단계, 이미지 2/2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashley Brooks
회원 가입일: 04/09/10
312 평판
안내서 4개 작성하였습니다
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 63개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 5,470
