주요 콘텐츠로 건너뛰기
Sony Walkman NWZ-S764 LCD Screen Replacement
필요한 것
  1. Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the back cover: 1 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the back cover: 1 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the back cover: 1 단계, 이미지 3/3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 LCD Screen Replacement: 2 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 2 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 LCD Screen Replacement: 3 단계, 이미지 1/2 Sony Walkman NWZ-S764 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 LCD Screen Replacement: 4 단계, 이미지 1/2 Sony Walkman NWZ-S764 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the Bluetooth module: 5 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the Bluetooth module: 5 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the Bluetooth module: 5 단계, 이미지 3/3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 LCD Screen Replacement: 6 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 6 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 6 단계, 이미지 3/3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
  7. Sony Walkman NWZ-S764 LCD Screen Replacement, Audio Port: 7 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement, Audio Port: 7 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement, Audio Port: 7 단계, 이미지 3/3
    • Remove the two 2.8mm silver Phillips screws on the sides of the frame.
    • The two 2.8mm screws are on each side of the device.
    • Insert a plastic prying tool between the bottom of the case and the motherboard.
    • Pry up the assembly and lift it away from the case.
  8. Sony Walkman NWZ-S764 LCD Screen Replacement: 8 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 8 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 8 단계, 이미지 3/3
    • Remove the yellow tape from the battery and volume control module.
    • Save tape for reassembly.
  9. Sony Walkman NWZ-S764 LCD Screen Replacement: 9 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 9 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 9 단계, 이미지 3/3
    • Use a prying tool to pry under the volume control module.
    • This module is glued on, using too much force may damage or warp the module.
  10. Sony Walkman NWZ-S764 LCD Screen Replacement: 10 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 10 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 10 단계, 이미지 3/3
    • Remove the tape from EMF shield and the LCD housing.
    • Lift up on the volume control ribbon.
  11. Sony Walkman NWZ-S764 LCD Screen Replacement: 11 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 11 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 11 단계, 이미지 3/3
    • Insert a plastic opening tool under the battery and lift up to remove it.
    • The battery is glued on, too much force may damage the battery casing.
    • The battery is soldered to the motherboard, care should be taken to not place too much stress on the wires.
  12. Sony Walkman NWZ-S764 LCD Screen Replacement: 12 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 12 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 12 단계, 이미지 3/3
    • Remove the black shielding tape from above the Hard Drive.
    • Peel the foam cover away from the hard drive.
    • Use a plastic opening tool to remove the EMF chip from the motherboard.
    • The hard drive is soldered onto the device. Be careful not to pull too hard on the hard drive.
  13. Sony Walkman NWZ-S764 LCD Screen Replacement: 13 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 13 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 13 단계, 이미지 3/3
    • Remove the plastic bracket by pushing up with your thumb to expose the display connection.
  14. Sony Walkman NWZ-S764 LCD Screen Replacement: 14 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 14 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 14 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
  15. Sony Walkman NWZ-S764 LCD Screen Replacement: 15 단계, 이미지 1/2 Sony Walkman NWZ-S764 LCD Screen Replacement: 15 단계, 이미지 2/2
    • Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
  16. Sony Walkman NWZ-S764 LCD Screen Replacement: 16 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 16 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 16 단계, 이미지 3/3
    • Remove the mic casing by pushing up and in.
    • Remove the headphone jack and the bottom casing.
  17. Sony Walkman NWZ-S764 LCD Screen Replacement, Motherboard: 17 단계, 이미지 1/2 Sony Walkman NWZ-S764 LCD Screen Replacement, Motherboard: 17 단계, 이미지 2/2
    • Use the prying tool to remove the LCD ribbon wire.
  18. Sony Walkman NWZ-S764 LCD Screen Replacement: 18 단계, 이미지 1/1
    • Lift up on the LCD ribbon and remove the two 1.8mm silver Phillips screws.
  19. Sony Walkman NWZ-S764 LCD Screen Replacement: 19 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 19 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 19 단계, 이미지 3/3
    • Lift the motherboard away from the frame with your thumb to remove it from the device.
    • Pull the volume control module through the space in the frame.
    • If you are using the magnetic project pad or other magnetic surface to keep your screws, do not place the hard drive on or near the magnet.
  20. Sony Walkman NWZ-S764 LCD Screen Replacement, LCD Screen: 20 단계, 이미지 1/2 Sony Walkman NWZ-S764 LCD Screen Replacement, LCD Screen: 20 단계, 이미지 2/2
    • To remove the LCD display cover, first melt the glue with the iOpener tool.
    • For more detailed instructions on how to use the iOpener, see iOpener Instructions
  21. Sony Walkman NWZ-S764 LCD Screen Replacement: 21 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 21 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 21 단계, 이미지 3/3
    • Carefully slide the iOpener wedge tool under the edge of the LCD display cover to separate it from the device.
    • Slide the wedge under all edges of the cover.
    • Once all of the glue has been broken, you can pull up on the cover to remove it.
    • The flat side of the spudger tool also works for this step
  22. Sony Walkman NWZ-S764 LCD Screen Replacement: 22 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 22 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 22 단계, 이미지 3/3
    • Remove the two 1.8 mm Phillips screws from both sides of the frame.
  23. Sony Walkman NWZ-S764 LCD Screen Replacement: 23 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 23 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 23 단계, 이미지 3/3
    • Use a strong pry tool to lift the metal brackets away from the device. You will need to bend the metal slightly to remove it from the dimples.
    • This step will require slight force to separate the frame. Do not bend the brackets too far so that they can be replaced later.
    • Once separated, pull the innermost frame containing the LCD display away from the brackets.
  24. Sony Walkman NWZ-S764 LCD Screen Replacement: 24 단계, 이미지 1/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 24 단계, 이미지 2/3 Sony Walkman NWZ-S764 LCD Screen Replacement: 24 단계, 이미지 3/3
    • Slide an opening pick under the LCD display to separate it from the rest of the device.
    • The pry tool also works for this step.
  25. Sony Walkman NWZ-S764 LCD Screen Replacement: 25 단계, 이미지 1/2 Sony Walkman NWZ-S764 LCD Screen Replacement: 25 단계, 이미지 2/2
    • Lift the LCD display off of the frame to remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Olson
회원 가입일: 01/21/15
175 평판
안내서 1개 작성함
USF Tampa, Team 4-2, Brown Winter 2015 USF Tampa, Team 4-2, Brown Winter 2015 회원
USFT-BROWN-W15S4G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 33
전체 시간: 1,955
