주요 콘텐츠로 건너뛰기
Sony Xperia XA1 Audio Jack Replacement
필요한 것
  1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: 1 단계, 이미지 1/3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: 1 단계, 이미지 2/3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: 1 단계, 이미지 3/3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: 2 단계, 이미지 1/3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: 2 단계, 이미지 2/3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: 2 단계, 이미지 3/3
    • Use a Phillips #000 Screwdriver to remove the three 3 mm screws from the top bracket.
  3. Sony Xperia XA1 Audio Jack Replacement: 3 단계, 이미지 1/3 Sony Xperia XA1 Audio Jack Replacement: 3 단계, 이미지 2/3 Sony Xperia XA1 Audio Jack Replacement: 3 단계, 이미지 3/3
    • Use a spudger to gently pry the three tabs at the top of the phone and release the camera cover.
    • Gently lift the cover.
  4. Sony Xperia XA1 Audio Jack Replacement: 4 단계, 이미지 1/3 Sony Xperia XA1 Audio Jack Replacement: 4 단계, 이미지 2/3 Sony Xperia XA1 Audio Jack Replacement: 4 단계, 이미지 3/3
    • Use the Phillips #000 Screwdriver to remove the 3 mm screw to the left of the audio jack component.
    • Use an opening tool to lift the audio jack connector.
    • Pinch the connector and remove the audio jack.
결론
Lindsey Taysom
회원 가입일: 02/14/23
205 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-4, McMurrin Spring 2023 Utah Tech University, Team 1-4, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 155
