주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia XA1 Battery Replacement
필요한 것
  1. Sony Xperia XA1 Battery Replacement, Phone Back Cover: 1 단계, 이미지 3개 중 1개 Sony Xperia XA1 Battery Replacement, Phone Back Cover: 1 단계, 이미지 3개 중 2개 Sony Xperia XA1 Battery Replacement, Phone Back Cover: 1 단계, 이미지 3개 중 3개
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Sony Xperia XA1 Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Disconnect the battery from the motherboard using an opening tool or spudger.
  3. Sony Xperia XA1 Battery Replacement: 3 단계, 이미지 3개 중 1개 Sony Xperia XA1 Battery Replacement: 3 단계, 이미지 3개 중 2개 Sony Xperia XA1 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the black tabs on either side of the battery
  4. Sony Xperia XA1 Battery Replacement: 4 단계, 이미지 3개 중 1개 Sony Xperia XA1 Battery Replacement: 4 단계, 이미지 3개 중 2개 Sony Xperia XA1 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the pull tab at the bottom to unseat the battery.
    • After unseating the battery with the pull tab, lift it out of the case.
    • Use caution handling the battery. It is extremely delicate.
  5. Sony Xperia XA1 Battery Replacement: 5 단계, 이미지 2개 중 1개 Sony Xperia XA1 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery entirely.
    • Do not dispose of your old battery in a regular trash can. Please bring your phone battery to a local home depot, best buy, or staples for safe disposal and recycling in the US and Canada. Other places in the world, please contact your local recycling centers.
결론
작성자
3다른 기여자 명과 함께
Lindsey Taysom
회원 가입일: 02/14/23
205 평판
안내서 2개를 작성함
Utah Tech University, Team 1-4, McMurrin Spring 2023 Utah Tech University, Team 1-4, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G4
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 22
지난 30일: 62
전체 시간: 1,343
