주요 콘텐츠로 건너뛰기
Sony Xperia XA1 Speaker Replacement
필요한 것
  1. Sony Xperia XA1 Speaker Replacement, Phone Back Cover: 1 단계, 이미지 1/3 Sony Xperia XA1 Speaker Replacement, Phone Back Cover: 1 단계, 이미지 2/3 Sony Xperia XA1 Speaker Replacement, Phone Back Cover: 1 단계, 이미지 3/3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Speaker Replacement, Speaker: 2 단계, 이미지 1/3 Sony Xperia XA1 Speaker Replacement, Speaker: 2 단계, 이미지 2/3 Sony Xperia XA1 Speaker Replacement, Speaker: 2 단계, 이미지 3/3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 Speaker Replacement: 3 단계, 이미지 1/3 Sony Xperia XA1 Speaker Replacement: 3 단계, 이미지 2/3 Sony Xperia XA1 Speaker Replacement: 3 단계, 이미지 3/3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 Speaker Replacement: 4 단계, 이미지 1/2 Sony Xperia XA1 Speaker Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 Speaker Replacement: 5 단계, 이미지 1/3 Sony Xperia XA1 Speaker Replacement: 5 단계, 이미지 2/3 Sony Xperia XA1 Speaker Replacement: 5 단계, 이미지 3/3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
결론
Hunter
회원 가입일: 02/14/23
349 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-4, McMurrin Spring 2023 Utah Tech University, Team 1-4, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 111
