주요 콘텐츠로 건너뛰기
Sony Xperia XA2 Ultra Speaker Replacement
필요한 것
  1. Sony Xperia XA2 Ultra Speaker Replacement, Rear Cover: 1 단계, 이미지 1/2 Sony Xperia XA2 Ultra Speaker Replacement, Rear Cover: 1 단계, 이미지 2/2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Speaker Replacement: 2 단계, 이미지 1/1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Speaker Replacement: 3 단계, 이미지 1/2 Sony Xperia XA2 Ultra Speaker Replacement: 3 단계, 이미지 2/2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Speaker Replacement: 4 단계, 이미지 1/2 Sony Xperia XA2 Ultra Speaker Replacement: 4 단계, 이미지 2/2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Speaker Replacement: 5 단계, 이미지 1/2 Sony Xperia XA2 Ultra Speaker Replacement: 5 단계, 이미지 2/2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Speaker Replacement: 6 단계, 이미지 1/1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Speaker Replacement, Speaker: 7 단계, 이미지 1/2 Sony Xperia XA2 Ultra Speaker Replacement, Speaker: 7 단계, 이미지 2/2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  8. Sony Xperia XA2 Ultra Speaker Replacement: 8 단계, 이미지 1/2 Sony Xperia XA2 Ultra Speaker Replacement: 8 단계, 이미지 2/2
    • Using an iFixit opening tool, pry and remove the speaker.
결론
Alyssa Bayles
회원 가입일: 09/27/22
819 평판
안내서 8개 작성하였습니다
Utah Tech University, Team 1-1, Randazzo Fall 2023 Utah Tech University, Team 1-1, Randazzo Fall 2023 회원
UTAHTECH-RANDAZZO-F23S1G1
1 회원
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 83
