소개
This guide will walk you through the process of replacing or taking off the back cover panel of the Sony Xperia XZ Premium with a heat source and a thin wedge. The heat source is very hot and can cause burning to the skin, so be very careful.
필요한 것
Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
이 단계에 사용된 도구:Plastic Cards$2.99
Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
