주요 콘텐츠로 건너뛰기
Sony Xperia XZ Premium Motherboard Replacement
필요한 것
  1. Sony Xperia XZ Premium Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Sony Xperia XZ Premium Motherboard Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Motherboard Replacement: 3 단계, 이미지 1/1
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Motherboard Replacement, Frame: 4 단계, 이미지 1/1
    • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
  5. Sony Xperia XZ Premium Motherboard Replacement: 5 단계, 이미지 1/2 Sony Xperia XZ Premium Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove nine 3.9mm Phillips #000 screws.
    • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • When unscrewing, remember "Left Loosey, Righty Tighty!"
  6. Sony Xperia XZ Premium Motherboard Replacement: 6 단계, 이미지 1/1
    • Place the spudger under the top left corner frame piece and lift to loosen.
  7. Sony Xperia XZ Premium Motherboard Replacement: 7 단계, 이미지 1/1
    • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
  8. Sony Xperia XZ Premium Motherboard Replacement: 8 단계, 이미지 1/1
    • Place the spudger under the bottom left frame piece and lift to loosen it.
  9. Sony Xperia XZ Premium Motherboard Replacement: 9 단계, 이미지 1/1
    • Grab hold of bottom left frame piece with your fingers and lift gently.
    • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
  10. Sony Xperia XZ Premium Motherboard Replacement: 10 단계, 이미지 1/1
    • Place the spudger under the top right frame piece and lift to loosen it.
  11. Sony Xperia XZ Premium Motherboard Replacement: 11 단계, 이미지 1/1
    • Grab hold of the top right frame piece with your fingers and lift.
  12. Sony Xperia XZ Premium Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Insert your nail under the top left connector and push to disconnect it.
  13. Sony Xperia XZ Premium Motherboard Replacement: 13 단계, 이미지 1/1
    • Grab hold of the metal part of the connector with your fingers and lift.
  14. Sony Xperia XZ Premium Motherboard Replacement: 14 단계, 이미지 1/1
    • Insert your nail under the metal part of the bottom left connector.
  15. Sony Xperia XZ Premium Motherboard Replacement: 15 단계, 이미지 1/1
    • Push the bottom left connector with your finger to disconnect it.
  16. Sony Xperia XZ Premium Motherboard Replacement: 16 단계, 이미지 1/1
    • Insert your nail under the center topmost connector and push to loosen it.
  17. Sony Xperia XZ Premium Motherboard Replacement: 17 단계, 이미지 1/1
    • Grab hold of the top connector with your fingers and lift to disconnect it.
  18. Sony Xperia XZ Premium Motherboard Replacement: 18 단계, 이미지 1/1
    • Insert your nail under the metal tab of the connector above the battery and push to loosen it.
  19. Sony Xperia XZ Premium Motherboard Replacement: 19 단계, 이미지 1/1
    • Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
  20. Sony Xperia XZ Premium Motherboard Replacement: 20 단계, 이미지 1/1
    • Insert spudger in the gap above the battery and lift to loosen the motherboard.
    • Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
  21. Sony Xperia XZ Premium Motherboard Replacement: 21 단계, 이미지 1/1
    • Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
  22. Sony Xperia XZ Premium Motherboard Replacement: 22 단계, 이미지 1/1
    • Grab hold of the motherboard with your fingers and lift it out of the phone gently.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Gelene Amog
회원 가입일: 04/18/18
1,165 평판
안내서 5개 작성하였습니다
Cal Poly, Team S18-G2, Livingston Spring 2018 Cal Poly, Team S18-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G2
5 회원들
안내서 16개 작성하였습니다
댓글 4개
Where do you buy a motherboard for the xz premium? thank you
Jonathan Storm - 답글
where can you buy a motherboard for the xz premium G8142?
dukeduane - 답글
If you know the name of the motherboard you can check on:
newegg.com
aliexpress.com
https://www.sony.com/electronics/support...
amazon.com
alibaba.com
Kristoffer Grundström -
Anyone know if you can replace the microphone on the XZ premium? I think it is attatched to the motherboard. Is it soldered on?
Tom M - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 33
전체 시간: 6,460
