주요 콘텐츠로 건너뛰기
Sony Xperia Z1s Rear Camera Replacement
필요한 것
  1. Sony Xperia Z1s Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/1
    • Insert the opening pick in the crease between the body of the phone and the phone's back cover.
    • Slide the opening pick around the crease until the back cover releases from the phone.
  2. Sony Xperia Z1s Rear Camera Replacement: 2 단계, 이미지 1/1
    • Using the T4 Torx screwdriver, remove the five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Rear Camera Replacement: 3 단계, 이미지 1/1
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Rear Camera Replacement: 4 단계, 이미지 1/1
    • Use the opening pick to pry off the camera flex cable.
  5. Sony Xperia Z1s Rear Camera Replacement: 5 단계, 이미지 1/1
    • Use the opening pick to lift the camera out of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amanda Simmons
회원 가입일: 09/28/21
148 평판
안내서 1개 작성함
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 138
