주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Back Cover Replacement
필요한 것
  1. Sony Xperia Z3 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Sony Xperia Z3 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Sony Xperia Z3 Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
    • If you use an iOpener, follow these instructions for use.
    • Lift up the back cover with a suction handle and put an opening pick in the gap.
    • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Don't put the pick in too deep under the back cover to not damage any parts inside the phone.
  2. Sony Xperia Z3 Back Cover Replacement: 2 단계, 이미지 1/2 Sony Xperia Z3 Back Cover Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • There are two adhesive strips in the center of the phone connecting the rear case to the battery, you'll need to remove them to open the phone.
    • When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
    • Use tweezers to pull the two black adhesive strips out of the phone but don't pull just yet.
  3. Sony Xperia Z3 Back Cover Replacement: 3 단계, 이미지 1/2 Sony Xperia Z3 Back Cover Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
    • If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again.
  4. Sony Xperia Z3 Back Cover Replacement: 4 단계, 이미지 1/2 Sony Xperia Z3 Back Cover Replacement: 4 단계, 이미지 2/2
    • After pulling out the adhesive tabs, you can lift the back cover and remove it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,802 평판
안내서 188개 작성하였습니다
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,083개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 45
전체 시간: 6,090
