주요 콘텐츠로 건너뛰기
Sophix TAB-730g Battery Replacement
필요한 것
  1. Sophix TAB-730g Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: 2 단계, 이미지 1/1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: 3 단계, 이미지 1/1
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: 4 단계, 이미지 1/1
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
결론
다른 2명이 해당 안내서를 완성하였습니다.
JT Hiquet
회원 가입일: 09/29/16
333 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-3, Harley Fall 2016 IUPUI, Team 2-3, Harley Fall 2016 회원
IUPUI-HARLEY-F16S2G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
[|how do you know if the problem is or is not the battery?]
Don Taylor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 367
