주요 콘텐츠로 건너뛰기
Spin Master Boxer Robot Battery Replacement
필요한 것
  1. Spin Master Boxer Robot Battery Replacement, Robot Screen: 1 단계, 이미지 1개 중 1개
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Battery Replacement: 4 단계, 이미지 2개 중 1개 Spin Master Boxer Robot Battery Replacement: 4 단계, 이미지 2개 중 2개
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Battery Replacement, Robot Battery: 6 단계, 이미지 2개 중 1개 Spin Master Boxer Robot Battery Replacement, Robot Battery: 6 단계, 이미지 2개 중 2개
    • Lift the top panel away from the main body of the robot to expose the yellow battery.
  7. Spin Master Boxer Robot Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Insert index finger in between battery and plastic shell of robot, and push battery out of the battery holder toward the wire.
  8. Spin Master Boxer Robot Battery Replacement: 8 단계, 이미지 1개 중 1개
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lauren Roide
회원 가입일: 04/16/19
739 평판
안내서 5개를 작성함
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 회원
CPSU-MANESS-S19S1G1
4 회원들
안내서 10개를 작성함
3가이드 댓글
Any tips on where to buy a replacement battery?
Chad Laughlin - 답글
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
Anton Litvinov - 답글
can we replace boxer’s USB slot?
Buchukoy Jimenez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 29
전체 시간: 2,615
