주요 콘텐츠로 건너뛰기
Spin Master Boxer Robot Speaker Replacement
필요한 것
  1. Spin Master Boxer Robot Speaker Replacement, Robot Screen: 1 단계, 이미지 1개 중 1개
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Speaker Replacement: 4 단계, 이미지 2개 중 1개 Spin Master Boxer Robot Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Speaker Replacement, Robot Speaker: 6 단계, 이미지 2개 중 1개 Spin Master Boxer Robot Speaker Replacement, Robot Speaker: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, unscrew the two 3mm screws connecting the black speaker cover to the top panel.
  7. Spin Master Boxer Robot Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the speaker cover and you will be left looking at the speaker.
    • The speaker is soldered onto the top panel so additional measures must be taken to completely remove it. See 연결부 납땜 및 납제거 방법
결론
작성자
2다른 기여자 명과 함께
Lauren Roide
회원 가입일: 04/16/19
739 평판
안내서 5개를 작성함
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 회원
CPSU-MANESS-S19S1G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,280
