주요 콘텐츠로 건너뛰기
Steam Deck OLED Screen Replacement
필요한 것
  1. Steam Deck OLED Screen Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 2개 중 1개 Steam Deck OLED Screen Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 2개 중 2개
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
  2. Steam Deck OLED Screen Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. Steam Deck OLED Screen Replacement, Heat the top edge screen adhesive: 3 단계, 이미지 1개 중 1개
    • Prepare an iOpener and apply it to the top edge of the screen for one minute.
    • You may also use a hair dryer or heat gun, but be careful not to overheat the device, as the screen, battery, and plastic frame are all susceptible to heat damage.
  4. Steam Deck OLED Screen Replacement, Apply a suction handle: 4 단계, 이미지 2개 중 1개 Steam Deck OLED Screen Replacement, Apply a suction handle: 4 단계, 이미지 2개 중 2개
    • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
  5. Steam Deck OLED Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
    • Pull up on the suction handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the screen panel, ambient light sensor, or sensor cable.
  6. Steam Deck OLED Screen Replacement, Remove the suction handle: 6 단계, 이미지 2개 중 1개 Steam Deck OLED Screen Replacement, Remove the suction handle: 6 단계, 이미지 2개 중 2개
    • Pull up on the nub on the back of the suction handle to remove it from the screen.
  7. Steam Deck OLED Screen Replacement, Screen information: 7 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Screen information: 7 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Screen information: 7 단계, 이미지 3개 중 3개
    • As you slice through the adhesive securing the screen, note the following:
    • Along the top and bottom edges, don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the sensors, sensors cable, or screen cable.
    • Along the left and right edges, don't insert your pick deeper than 5 mm (~1/5 of an inch) to avoid damaging the screen panel.
  8. Steam Deck OLED Screen Replacement, Reposition the pick: 8 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Reposition the pick: 8 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Reposition the pick: 8 단계, 이미지 3개 중 3개
    • Rotate the pick so its flat edge is between the screen and frame.
    • Leave this pick inserted to prevent the adhesive from resealing.
  9. Steam Deck OLED Screen Replacement, Separate the top edge adhesive: 9 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Separate the top edge adhesive: 9 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Separate the top edge adhesive: 9 단계, 이미지 3개 중 3개
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the top edge.
    • Insert another pick in the top left corner.
    • Slide the pick toward the power button to separate the adhesive securing the top edge of the screen.
  10. Steam Deck OLED Screen Replacement, Reposition the pick: 10 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Reposition the pick: 10 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Reposition the pick: 10 단계, 이미지 3개 중 3개
  11. Steam Deck OLED Screen Replacement, Heat the right edge screen adhesive: 11 단계, 이미지 1개 중 1개
    • Heat the right edge of the screen for one minute.
  12. Steam Deck OLED Screen Replacement, Separate the right edge adhesive: 12 단계, 이미지 2개 중 1개 Steam Deck OLED Screen Replacement, Separate the right edge adhesive: 12 단계, 이미지 2개 중 2개
    • Don't insert your pick deeper than 5 mm (~1/5 of an inch) along the right edge.
    • Insert another pick just below the right thumbstick.
    • Slide the pick to the bottom right corner to separate the right edge adhesive.
    • Leave the pick inserted to prevent the adhesive from resealing.
  13. Steam Deck OLED Screen Replacement, Heat the bottom edge adhesive: 13 단계, 이미지 1개 중 1개
    • Heat the bottom edge of the screen for one minute.
  14. Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: 14 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: 14 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: 14 단계, 이미지 3개 중 3개
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the bottom edge.
    • Insert another pick in bottom right corner along the bottom edge.
    • Slide the pick to the bottom left corner to separate the bottom edge adhesive.
  15. Steam Deck OLED Screen Replacement, Lift the top edge of the screen: 15 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Lift the top edge of the screen: 15 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Lift the top edge of the screen: 15 단계, 이미지 3개 중 3개
    • Grip the two picks along the top edge.
    • Pry up to lift the top edge of the screen away from the frame until you can grab it.
    • If the screen feels stuck, go back around the perimeter and check for missed sections of adhesive. If you're using a hair dryer, use it to lightly heat the stuck sections of adhesive.
  16. Steam Deck OLED Screen Replacement, Flip the screen over: 16 단계, 이미지 3개 중 1개 Steam Deck OLED Screen Replacement, Flip the screen over: 16 단계, 이미지 3개 중 2개 Steam Deck OLED Screen Replacement, Flip the screen over: 16 단계, 이미지 3개 중 3개
    • Be gentle with the screen, as straining its cable may damage the socket on the motherboard.
    • Flip the screen over the bottom edge of the frame.
    • Prop up the screen with a small box or book roughly 2.5 cm (~1 inch) thick.
    • If you don't have a box or book nearby, hold the screen in this position for the next two steps.
  17. Steam Deck OLED Screen Replacement, Unlatch the screen connector: 17 단계, 이미지 2개 중 1개 Steam Deck OLED Screen Replacement, Unlatch the screen connector: 17 단계, 이미지 2개 중 2개
    • Use the point of a spudger or a clean fingernail to flip up the locking flap on the outside edge of the screen ZIF connector.
    • Don't touch any of the small surface-mounted components around the connector.
  18. Steam Deck OLED Screen Replacement, Disconnect the screen: 18 단계, 이미지 2개 중 1개 Steam Deck OLED Screen Replacement, Disconnect the screen: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to grip the screen cable pull tab and slide the cable straight out of its socket to disconnect it.
  19. Steam Deck OLED Screen Replacement, Remove the screen: 19 단계, 이미지 1개 중 1개
결론
To reapply adhesive and install your screen, follow this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
95,437 평판
안내서 465개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,769개를 작성함
9가이드 댓글
I successfully swapped matte/glossy OLED model screens this way. First boot after swap had a frazzled screen. Hard reset fixed the problem instantly.
keyscameron - 답글
Is this compatible with limited edition?
Joen Liwanag - 답글
the steps are the same for both OLED models. However the LE comes stock with a matte screen, standard model with glossy screen
keyscameron -
Is it possible to upgrade Steam Deck 512GB LCD model to better matte OLED screen?
As well as upgrade the WiFi card?
gurenmkd - 답글
No for the screen, i do not know for wifi. i doubt it.
keyscameron -
댓글 쓰기
조회 통계:
지난 24시간: 68
지난 7일: 368
지난 30일: 1,955
전체 시간: 31,326
