주요 콘텐츠로 건너뛰기
Steam Iron - Step 2: How does it work?
동영상 개요
  1. Steam Iron - Step 2: How does it work?, General operating principle: 1 단계, 이미지 3개 중 1개 Steam Iron - Step 2: How does it work?, General operating principle: 1 단계, 이미지 3개 중 2개 Steam Iron - Step 2: How does it work?, General operating principle: 1 단계, 이미지 3개 중 3개
    • When the Start button is pressed (item 1), a circuit is closed which powers, via a relay (item 2), the heating resistor placed in the soleplate of the iron (item 6). When the temperature is reached, a beep is heard (after about 2 minutes)
    • After the beep, steam can be produced by pressing the button in the iron's handle (figure 5) Thus, a circuit is closed which turns on a pump placed in the frame beneath the water tank (figure 3) This pump, placed between the tank (figure 4) and the iron will make the water flow from one to the other
    • The water, being carried into the iron's soleplate through soft tubing, will turn to steam when coming into contact with the heating resistor. Indeed, because of the heat (around 130°C-160°C), the water turns to steam and escapes through the holes in the sole. By releasing the button, the pump stops and so does the steam.
  2. Steam Iron - Step 2: How does it work?, Water pump operation: 2 단계, 이미지 3개 중 1개 Steam Iron - Step 2: How does it work?, Water pump operation: 2 단계, 이미지 3개 중 2개 Steam Iron - Step 2: How does it work?, Water pump operation: 2 단계, 이미지 3개 중 3개
    • The device is made of several smaller bodies that we will look at seperately. We shall start with the water pump.
    • This kind of pump, called a suction pump, is frequently found in devices requiring the pressurizing of liquids, usually water. They can be found in expresso coffee machines (pressurized hot water for percolation), and certain steam irons.
    • The axial movement of a metallic piston (Fig. A), perforated at both ends so as to create the movement of the water, creates the pressure in the system. The back and forth is driven by a magnetic field created by a reel. You can see these parts by following the link at the end of this step.
    • The reel contains a diode in series with the coiling, which allows power from a single-phase, full-wave rectified voltage. Put simply, the piston follows the electrical current (50hz) and oscillates with 25 backs and 25 forths per second.
    • This very pronounced vibration is the source of the very recognizable sound of a functioning pump.
    • Water arrives on one side of the pump (yellow arrow on the schematic) goes through the actuator (Fig. A), and arrives in the pale pink chamber. This chamber is alternatively closed of by two valves, pink (Fig. B) and blue (Fig. C) The pink one lets the water into the chamber when the piston is released, and the blue one is closed.
    • When the piston is driven, the pink valve closes, the chamber is pressurized, forcing the blue valve open and letting the water through. This cycle is renewed 25 times per second.
    • Animation showing the pump in operation.
  3. Steam Iron - Step 2: How does it work?, Electronic Circuit Operation: 3 단계, 이미지 3개 중 1개 Steam Iron - Step 2: How does it work?, Electronic Circuit Operation: 3 단계, 이미지 3개 중 2개 Steam Iron - Step 2: How does it work?, Electronic Circuit Operation: 3 단계, 이미지 3개 중 3개
    • The device has a printed circuit board (PCB) located in the base of the tank. The operation of the device is entrusted to a microcontroller (Fig. 15)(PIC16F1820). This manages the inputs-outputs of the device connected to the various elements, probe, sensor, pump and control panel in order to ensure proper heating of the iron.
    • Iron soleplate temperature management. It is carried out by means of a probe placed in contact with the soleplate. This iron does not have a manual thermostat to adjust the temperature of the iron. The temp is fixed and is controlled by the probe (see next step in Fig. 8) The temp measured on the soleplate of the iron is 160°C.
    • Pump flow management using a BT168 GW thyristor (Fig. 16)(BT168 GW). This allows the volume of steam to be reduced in ECO mode or increased in TURBO mode.
    • Iron inclination management. This iron has a tilt or motion sensor (Fig. 12). This takes the form of a capsule containing a metal ball. When the iron is horizontal, the ball closes the circuit, allowing the resistor to heat up. When the iron is tilted (on its base for example), the circuit is open, and the resistor is no longer powered.
    • Descaling management By pressing the descale button, the pump operates for 2 minutes without interruption with the maximum flow rate. The iron will signal whenever descaling is needed. The micro-controller is programmed to manage this alert and will stop the pump if the operation is not started.
    • Light and sound signal management. 3 LEDs are placed on the printed circuit opposite each button of the control panel as well as a buzzer. The signals emitted by these components are described in step 3 of the "different functions" tutorial. Another led (Fig. 14) is connected to a small PCB board placed in the handle of the iron.
    • This small PCB board also supports the steam switch (Fig. 13) which is activated by the steam button (Fig. 5) and the tilt sensor (Fig. 12).
  4. Steam Iron - Step 2: How does it work?, Electric circuit operation: 4 단계, 이미지 3개 중 1개 Steam Iron - Step 2: How does it work?, Electric circuit operation: 4 단계, 이미지 3개 중 2개 Steam Iron - Step 2: How does it work?, Electric circuit operation: 4 단계, 이미지 3개 중 3개
    • The electrical circuit is made up of a power cord with 3 conductors: Phase (brown), Neutral (blue), and Ground (green/yellow). These three wires are connected to the electronic board. The ground wire is extended towards the iron through a protective sheath.
    • In this sheath are also the wires that will supply the heating resistor (Fig. 11) via the Klixon protection (Fig. 9) and the temperature sensor (Fig. 8) as well as the control wires (M/A button, led. ..) which is in the handle of the iron. The pipe through which the water circulates is found there as well (Fig 10).
    • The attached diagram shows the main elements and their connections.
  5. Steam Iron - Step 2: How does it work?, Hydraulic circuit operation: 5 단계, 이미지 1개 중 1개
    • The water circuit is as follows (red): the water is stored in the reservoir (Fig. 4) When the user requests steam by pressing the button placed in the handle of the iron (Fig. 5), the pump (Fig 3) is started. The water is then sucked up and sent through the tube (Fig. 10) to the sole of the iron (Fig. 6).
    • A safety bypass is located at the outlet of the pump (Fig. 17) If the water cannot be evacuated (clogged pipe) it returns to the tank (green).
결론
Now that we know the functionalities of our device and we know the sub-assemblies and the operation, we can move on to the repair phase with the following tutorial: "Steam iron, Step 3: common breakdowns" (Please note that this page is currently untranslated.)
다른 20명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
Atelier Soudé
회원 가입일: 12/13/18
3,691 평판
안내서 15개를 작성함
Atelier Soudé Atelier Soudé 회원
Local Repair Groups
5 회원들
안내서 30개를 작성함
댓글 6개
Thank you for this guide, identifying the components was helpful. If there are some links for troubleshooting the pump system you would recommend, I would appreciate it as well. Let's make things repairable :)
civilizati3 - 답글
Same problem happened with me also. Pump of my iron is not working and it is very difficult to find the same in India. If there are some links for troubleshooting the pump system you would recommend, I would appreciate it as well. Let's make things repairable :)
Satnam Singh - 답글
Does your pump run when you press the calc button?
TheNightOwl -
You shared very useful information, thank you very-very-very much!!!
Vedrasco Victor Vasili - 답글
Hello,
Thank you for the guide.
I replaced the pump with new one but it doesn't work. The new pump works well outside the system.please where would be the problem.
Mohamed - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 79
지난 30일: 305
전체 시간: 19,824
