주요 콘텐츠로 건너뛰기
SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement
필요한 것
  1. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Ear Cushions: 1 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Ear Cushions: 1 단계, 이미지 2개 중 2개
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Circuit Board: 2 단계, 이미지 1개 중 1개
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: 6 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: 6 단계, 이미지 2개 중 2개
    • Flip the circuit board over and remove the keycap by pulling on it.
  7. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button: 7 단계, 이미지 1개 중 1개
    • Desolder the wires connecting the button to the circuit board.
    • For help desoldering connections, follow this useful guide on 연결부 납땜 및 납제거 방법.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 8 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 8 단계, 이미지 2개 중 2개
    • Desolder the three pins to remove the button from the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kyle Chang
회원 가입일: 01/24/19
1,170 평판
안내서 7개를 작성함
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 회원
CPSU-WHITE-W19S18G1
4 회원들
안내서 21개를 작성함
10 Guide Comments
Where can you get the replacement switch?
Jason Rosa - 답글
Can you provide any specs for this switch? I’d like to buy the replacement switch before disassembling the headset.
DAA - 답글
I also need to know where to get the replacement switch from !
Trevor Peters - 답글
If anyone wants to try it (I have not), I think the G type switch will work. BUT you will have to find a way to mount it, as it does not have the Metal case for soldering to the PCB.
Searchebay.co.uk for 11 Types, DPDT Self Latching Locking Momentary Push Button PCB SMD Switch 6 Pin
Select Type G
Try at your own risk and good luck
Trevor Peters - 답글
BTW, the size of the switch is 5.8 x 5.8 mm
DAA - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 31
지난 30일: 192
전체 시간: 11,168
