주요 콘텐츠로 건너뛰기
SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
필요한 것
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 1 단계, 이미지 1/3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 1 단계, 이미지 2/3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 1 단계, 이미지 3/3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 2 단계, 이미지 1/2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 2 단계, 이미지 2/2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 3 단계, 이미지 1/2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 3 단계, 이미지 2/2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 4 단계, 이미지 1/2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 4 단계, 이미지 2/2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 5 단계, 이미지 1/1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 6 단계, 이미지 1/2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 6 단계, 이미지 2/2
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Avinash Vadlamudi
회원 가입일: 01/24/19
451 평판
안내서 1개 작성함
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 회원
CPSU-WHITE-W19S18G1
4 회원들
안내서 21개 작성하였습니다
댓글 3개
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - 답글
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - 답글
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 25
30일 전: 80
전체 시간: 4,419
