주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SuperSonic Matrix Mid SC-999 Battery Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
    댓글 쓰기
  2. SuperSonic Matrix Mid SC-999 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
    댓글 쓰기
  3. SuperSonic Matrix Mid SC-999 Battery Replacement: 3 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the back cover from the body of the device to expose the internal components.
    댓글 쓰기
  4. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
    댓글 쓰기
  5. SuperSonic Matrix Mid SC-999 Battery Replacement: 5 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Battery Replacement: 5 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Collin Ferguson
회원 가입일: 03/24/15
176 평판
안내서 1개를 작성함
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 회원
BU-SHAVER-S15S6G1
4 회원들
안내서 18개를 작성함
1가이드 댓글
Link to the soldering technique guide!
Josh Lewis - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 2,695
