주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 Battery Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Battery Replacement: 2 단계, 이미지 1/1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Battery Replacement: 3 단계, 이미지 1/2 SuperSonic Matrix Mid SC-999 Battery Replacement: 3 단계, 이미지 2/2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 4 단계, 이미지 1/3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 4 단계, 이미지 2/3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Battery Replacement: 5 단계, 이미지 1/3 SuperSonic Matrix Mid SC-999 Battery Replacement: 5 단계, 이미지 2/3 SuperSonic Matrix Mid SC-999 Battery Replacement: 5 단계, 이미지 3/3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Collin Ferguson
회원 가입일: 03/24/15
176 평판
안내서 1개 작성함
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 회원
BU-SHAVER-S15S6G1
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Link to the soldering technique guide!
Josh Lewis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 2,337
