주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 FM Antenna Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Back Cover: 1 단계, 이미지 1/1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 2 단계, 이미지 1/1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 3 단계, 이미지 1/2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 3 단계, 이미지 2/2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: 4 단계, 이미지 1/3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: 4 단계, 이미지 2/3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: 4 단계, 이미지 3/3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 5 단계, 이미지 1/3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 5 단계, 이미지 2/3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 5 단계, 이미지 3/3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, FM Antenna: 6 단계, 이미지 1/2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, FM Antenna: 6 단계, 이미지 2/2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  7. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 7 단계, 이미지 1/2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: 7 단계, 이미지 2/2
    • Desolder the FM antenna from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Harris Dagha
회원 가입일: 03/26/15
866 평판
안내서 7개 작성하였습니다
Dr Shaverz boyz Dr Shaverz boyz 회원
Community
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 201
