소개
In this guide you will open up the back of the device and locate the 3.5mm headphone jack on the mother board. Once it is found you must remove it with a soldering iron and replace it.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
필요한 것
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
거의 끝나갑니다!
결론
