주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 LCD Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 LCD Replacement: 3 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 4 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 4 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 LCD Replacement: 5 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 5 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  7. SuperSonic Matrix Mid SC-999 LCD Replacement: 7 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 7 단계, 이미지 2개 중 2개
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
  8. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: 8 단계, 이미지 1개 중 1개
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  9. SuperSonic Matrix Mid SC-999 LCD Replacement: 9 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 9 단계, 이미지 2개 중 2개
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
  10. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: 10 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: 10 단계, 이미지 2개 중 2개
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  11. SuperSonic Matrix Mid SC-999 LCD Replacement: 11 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 11 단계, 이미지 2개 중 2개
    • Desolder the FM antenna from the motherboard.
  12. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
    • Remove the large ribbon cable from the socket that attaches it to the motherboard.
    • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
  13. SuperSonic Matrix Mid SC-999 LCD Replacement: 13 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the small ribbon cable from the socket that attaches it to the motherboard.
    • Flip the dark grey latch to release the ribbon cable from the motherboard.
  14. SuperSonic Matrix Mid SC-999 LCD Replacement: 14 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement: 14 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 LCD Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the four Phillips #00 screws attaching the motherboard to the device.
  15. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 15 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 15 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 15 단계, 이미지 3개 중 3개
    • Ensure that the motherboard and all other items are off before continuing.
    • Separate the screen and back housing by gently pulling on it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Harris Dagha
회원 가입일: 03/26/15
866 평판
안내서 7개를 작성함
Dr Shaverz boyz Dr Shaverz boyz 회원
Community
3 회원들
안내서 14개를 작성함
1가이드 댓글
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 1,183
