주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 Microphone Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Microphone Replacement: 3 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Microphone Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Microphone Replacement, Microphone: 4 단계, 이미지 1개 중 1개
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  5. SuperSonic Matrix Mid SC-999 Microphone Replacement: 5 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Microphone Replacement: 5 단계, 이미지 2개 중 2개
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
결론
작성자
3다른 기여자 명과 함께
Harris Dagha
회원 가입일: 03/26/15
866 평판
안내서 7개를 작성함
Dr Shaverz boyz Dr Shaverz boyz 회원
Community
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 223
