주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 Screen Sensor Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Taking Out the First Screw: 2 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Taking Out the First Screw: 2 단계, 이미지 2개 중 2개
    • Find the first screw at the top left underneath the gold film and use a J0 Phillips Head screwdriver to unscrew it.
  2. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Taking Out the Second Screw: 3 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Taking Out the Second Screw: 3 단계, 이미지 2개 중 2개
    • Find the second screw located above the white and grey box for the film for the camera and use the same screwdriver from step two to unscrew it.
  3. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Taking Out the Third Screw: 4 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Taking Out the Third Screw: 4 단계, 이미지 2개 중 2개
    • Find the third screw at top right corner below the USB port and use the same screwdriver from the previous two steps.
  4. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing Gold Film Pt. 1: 5 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing Gold Film Pt. 1: 5 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing Gold Film Pt. 1: 5 단계, 이미지 3개 중 3개
    • Find the gold film at the top left of the tablet, connect to the screen.
    • Refer to step six in thecamera replacement guide to remember how to open and pull out the gold film
  5. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Revoming Gold Film Pt. 2: 6 단계, 이미지 1개 중 1개
    • Find the gold film on the bottom right, connected to the screen sensor.
    • Use the method from the previous step to disconnect the gold film.
  6. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Finding the Grey Wire: 7 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Finding the Grey Wire: 7 단계, 이미지 2개 중 2개
    • Find the grey wire that connects at the green plate (The Motherboard) and at the bottom of the Screen Sensor.
    • The wire is connected by a white sticker to the Screen Sensor
  7. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Peeling the Sticker Off: 8 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Peeling the Sticker Off: 8 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Peeling the Sticker Off: 8 단계, 이미지 3개 중 3개
    • Carefully peel the sticker off the back of the screen sensor. DO NOT RIP THE STICKER!!
  8. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Finding the Battery: 9 단계, 이미지 1개 중 1개
    • Look under the motherboard to find the battery. There will be yellow tape and black and red wires on the top of the battery.
  9. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing the Battery: 10 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing the Battery: 10 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing the Battery: 10 단계, 이미지 3개 중 3개
    • Carefully pull up on the edges of the battery with your hands. The motherboard will come with it.
  10. SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing the Screen Sensor: 11 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing the Screen Sensor: 11 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Screen Sensor Replacement, Removing the Screen Sensor: 11 단계, 이미지 3개 중 3개
    • Use the wedge from the camera replacement guide to go in between the silver lining of the Screen Sensor and Screen of the tablet.
결론
작성자
2다른 기여자 명과 함께
Logan Robinson
회원 가입일: 09/18/18
493 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 254
