주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 Speaker Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Speaker Replacement: 2 단계, 이미지 1/1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Speaker Replacement: 3 단계, 이미지 1/2 SuperSonic Matrix Mid SC-999 Speaker Replacement: 3 단계, 이미지 2/2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  5. SuperSonic Matrix Mid SC-999 Speaker Replacement: 5 단계, 이미지 1/2 SuperSonic Matrix Mid SC-999 Speaker Replacement: 5 단계, 이미지 2/2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
결론
Johncy George
회원 가입일: 03/26/15
101 평판
안내서 1개 작성함
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 회원
BU-SHAVER-S15S6G1
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 303
