주요 콘텐츠로 건너뛰기
Supersonic Matrix SC-91MID Speakers Replacement
필요한 것
  1. Supersonic Matrix SC-91MID Speakers Replacement, Back cover: 1 단계, 이미지 1/1
    • Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
    • Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
  2. Supersonic Matrix SC-91MID Speakers Replacement: 2 단계, 이미지 1/1
    • Use a spudger to carefully disconnect the display ribbons from the motherboard.
  3. Supersonic Matrix SC-91MID Speakers Replacement: 3 단계, 이미지 1/1
    • To remove the battery, use the spudger to pry the battery up and away from the tablet.
    • You might have some difficulty removing due to glue holding the battery in place.
    • Work your way around the perimeter of the battery with the spudger or opening picks gently so you don't bend or puncture the battery.
  4. Supersonic Matrix SC-91MID Speakers Replacement: 4 단계, 이미지 1/2 Supersonic Matrix SC-91MID Speakers Replacement: 4 단계, 이미지 2/2
    • Use a spudger to remove the speakers.
    • To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
  5. Supersonic Matrix SC-91MID Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Desolder the four speaker wires connecting the speaker to the motherboard using a soldering station.
    • If you're unfamiliar with soldering or desoldering check out this guide How To Solder and Desolder Connections
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    • The tool in the picture is not required for this step. It is just being used to point out the wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Osborn
회원 가입일: 03/21/17
134 평판
안내서 1개 작성함
Texas Tech, Team S46-G4, Bennett Spring 2017 Texas Tech, Team S46-G4, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 194
