주요 콘텐츠로 건너뛰기
Swann Wi-Fi Indoor Security Camera Microphone Replacement
필요한 것
  1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: 1 단계, 이미지 1/3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: 1 단계, 이미지 2/3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: 1 단계, 이미지 3/3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Microphone Replacement: 2 단계, 이미지 1/1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Microphone Replacement: 3 단계, 이미지 1/1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: 4 단계, 이미지 1/3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: 4 단계, 이미지 2/3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: 4 단계, 이미지 3/3
    • Locate microphone and pull to dislodge from the holder.
    • Disconnect the connector located on the main board to finish disconnecting the microphone.
결론
Logan Sluder
회원 가입일: 09/18/19
544 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 736
