주요 콘텐츠로 건너뛰기
Swann Wi-Fi Indoor Security Camera SD Card Replacement
필요한 것
  1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: 1 단계, 이미지 1/3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: 1 단계, 이미지 2/3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: 1 단계, 이미지 3/3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera SD Card Replacement: 2 단계, 이미지 1/1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera SD Card Replacement: 3 단계, 이미지 1/1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: 4 단계, 이미지 1/3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: 4 단계, 이미지 2/3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: 4 단계, 이미지 3/3
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
  5. Swann Wi-Fi Indoor Security Camera SD Card Replacement: 5 단계, 이미지 1/1
    • With the motherboard removed, flip it over and remove the SD card by pushing in the SD card, releasing it.
결론
Logan Sluder
회원 가입일: 09/18/19
544 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 28
전체 시간: 1,309
