주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
System x3650 CPU and Memory Replacement
필요한 것
  1. System x3650 CPU and Memory Replacement, CPU and Memory: 1 단계, 이미지 2개 중 1개 System x3650 CPU and Memory Replacement, CPU and Memory: 1 단계, 이미지 2개 중 2개
    • Make sure that you have unplugged the power cable before servicing.
    • Pull the latch on the top cover up.
    • Slide the cover out.
  2. System x3650 CPU and Memory Replacement: 2 단계, 이미지 3개 중 1개 System x3650 CPU and Memory Replacement: 2 단계, 이미지 3개 중 2개 System x3650 CPU and Memory Replacement: 2 단계, 이미지 3개 중 3개
    • Press the two latches on the riser card assembly, indicated by blue arrows and outlines.
    • Slowly take the the riser card assembly out.
    • Doing so will allow you to remove the white plastic airflow guides.
    • This will provide access to the computer parts that you want to replace.
  3. System x3650 CPU and Memory Replacement: 3 단계, 이미지 1개 중 1개
    • Move the heat sink bracket lever to the open position and remove the heat sink.
    • This will provide access to the processor.
  4. System x3650 CPU and Memory Replacement: 4 단계, 이미지 2개 중 1개 System x3650 CPU and Memory Replacement: 4 단계, 이미지 2개 중 2개
    • Open the CPU retention bracket lever.
    • Remove the old processor from the socket.
  5. System x3650 CPU and Memory Replacement: 5 단계, 이미지 2개 중 1개 System x3650 CPU and Memory Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the old RAM if it is being replaced.
    • Unfasten the clamps on both ends of the slot.
    • Take out the memory module.
  6. System x3650 CPU and Memory Replacement: 6 단계, 이미지 2개 중 1개 System x3650 CPU and Memory Replacement: 6 단계, 이미지 2개 중 2개
    • Insert the new memory modules into the empty RAM slots securely.
    • The clamps on both ends of the slot should click into place.
    • See this link for the DIMM installation sequence.
  7. System x3650 CPU and Memory Replacement: 7 단계, 이미지 3개 중 1개 System x3650 CPU and Memory Replacement: 7 단계, 이미지 3개 중 2개 System x3650 CPU and Memory Replacement: 7 단계, 이미지 3개 중 3개
    • Insert new CPU into socket.
    • Ensure that the CPU chip is positioned correctly (i.e. its marked corner is facing bottom left).
    • Apply thermal paste to the top of the processor if necessary.
    • Close the CPU retention bracket lever.
    • An insecure or improper placement can damage a CPU or the socket pinout.
  8. System x3650 CPU and Memory Replacement: 8 단계, 이미지 1개 중 1개
    • Place the heat sink on top of the CPU.
    • Move the heat sink bracket lever to closed position.
  9. System x3650 CPU and Memory Replacement: 9 단계, 이미지 3개 중 1개 System x3650 CPU and Memory Replacement: 9 단계, 이미지 3개 중 2개 System x3650 CPU and Memory Replacement: 9 단계, 이미지 3개 중 3개
    • If you need to add a second processor, move the heat sink bracket lever to open position.
    • Take out the white plastic cover on the second socket.
    • Repeat steps 7 and 8 for the second CPU/socket (insert a CPU and a heat sink).
  10. System x3650 CPU and Memory Replacement: 10 단계, 이미지 3개 중 1개 System x3650 CPU and Memory Replacement: 10 단계, 이미지 3개 중 2개 System x3650 CPU and Memory Replacement: 10 단계, 이미지 3개 중 3개
    • Insert the plastic airflow guides back in their places.
    • Insert the riser card assembly, pushing it into its slot.
  11. System x3650 CPU and Memory Replacement: 11 단계, 이미지 2개 중 1개 System x3650 CPU and Memory Replacement: 11 단계, 이미지 2개 중 2개
    • Slide the top cover in place firmly.
    • Ensure that the latch is in the down position.
결론
Follow this guide to replace or upgrade CPU and memory on IBM System x3650. Up to 2 processors can be installed. Up to 48 GB of RAM can be installed.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Serguei Potechnykh
회원 가입일: 09/16/20
220 평판
안내서 1개를 작성함
York University, Team S2-G21, Melo-Thaiss Fall 2020 York University, Team S2-G21, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G21
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 99
전체 시간: 3,341
