주요 콘텐츠로 건너뛰기
TDK Life on Record Trek Max A34 Small Speaker Replacement
필요한 것
  1. TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: 1 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: 1 단계, 이미지 2/2
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  2. TDK Life on Record Trek Max A34 Small Speaker Replacement: 2 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 2 단계, 이미지 2/2
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  3. TDK Life on Record Trek Max A34 Small Speaker Replacement: 3 단계, 이미지 1/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 3 단계, 이미지 2/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 3 단계, 이미지 3/3
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  4. TDK Life on Record Trek Max A34 Small Speaker Replacement: 4 단계, 이미지 1/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 4 단계, 이미지 2/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 4 단계, 이미지 3/3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  5. TDK Life on Record Trek Max A34 Small Speaker Replacement: 5 단계, 이미지 1/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 5 단계, 이미지 2/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 5 단계, 이미지 3/3
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  6. TDK Life on Record Trek Max A34 Small Speaker Replacement: 6 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 6 단계, 이미지 2/2
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
    • Remove the top cover.
  7. TDK Life on Record Trek Max A34 Small Speaker Replacement: 7 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 7 단계, 이미지 2/2
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  8. TDK Life on Record Trek Max A34 Small Speaker Replacement: 8 단계, 이미지 1/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 8 단계, 이미지 2/3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 8 단계, 이미지 3/3
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mario Lazaga
회원 가입일: 01/14/19
1 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G3, Wilson Spring 2019 IUPUI, Team S3-G3, Wilson Spring 2019 회원
IUPUI-WILSON-S19S3G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 361
