주요 콘텐츠로 건너뛰기
TECHUP Bluetooth Speaker Motherboard Replacement
필요한 것
  1. TECHUP Bluetooth Speaker Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Pry the foam buffer from the speaker using a nylon spudger or flathead screwdriver (pictured).
    • You will need to re-apply adhesive if you want to reattach this foam after removing it.
  2. TECHUP Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 3개 중 1개 TECHUP Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 3개 중 2개 TECHUP Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two bottom screws using a Phillips #0 screwdriver.
  3. TECHUP Bluetooth Speaker Motherboard Replacement: 3 단계, 이미지 2개 중 1개 TECHUP Bluetooth Speaker Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the plastic casing away from the speaker.
    • You may have to twist-and-pull to remove it.
  4. TECHUP Bluetooth Speaker Motherboard Replacement: 4 단계, 이미지 2개 중 1개 TECHUP Bluetooth Speaker Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Desolder the two battery wires from the motherboard.
    • Because you are dealing with battery connections, be aware of the shock hazard.
  5. TECHUP Bluetooth Speaker Motherboard Replacement: 5 단계, 이미지 2개 중 1개 TECHUP Bluetooth Speaker Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Desolder the two speaker wires from the motherboard.
  6. TECHUP Bluetooth Speaker Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Grasp the motherboard and pull it from the encasement.
    • Take care to not rip the wires as you pull the motherboard out, as they may catch in the grooves on the motherboard.
  7. TECHUP Bluetooth Speaker Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Pry the battery from the motherboard using a nylon spudger.
    • You may have to apply significant force to the motherboard to remove the battery.
    • Always use an ESD-safe tool, such as a nylon spudger, when working with batteries. Metal tools can puncture an unprotected battery, potentially causing a fire.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ismael Castaneda
회원 가입일: 09/28/21
220 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 27
지난 30일: 77
전체 시간: 3,234
