주요 콘텐츠로 건너뛰기
TI-Nspire CX Battery Replacement
필요한 것
  1. TI-Nspire CX Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: 2 단계, 이미지 2개 중 1개 TI-Nspire CX Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: 3 단계, 이미지 3개 중 1개 TI-Nspire CX Battery Replacement: 3 단계, 이미지 3개 중 2개 TI-Nspire CX Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the back plate and the 2 screws.
결론
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jim Kerman
회원 가입일: 02/24/15
335 평판
안내서 1개를 작성함
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 회원
CPSU-GREEN-W15S24G2
4 회원들
안내서 4개를 작성함
댓글 2개
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - 답글
Hola Amigo. Pudiste solucionar?
Armando02 -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 29
지난 30일: 101
전체 시간: 17,572
